WHAT SIZE GAS TANK 22 or 15
Old Jul 7, 2010 | 08:24 PM
2daks's Avatar
2daks
Default WHAT SIZE GAS TANK 22 or 15
97 Dakota V6 3.9L ext cab. Need to replace the fuel pump. Seems most fuel tanks are 22 gal but want to make sure before I buy the new pump module.
I sent off for the build sheet but want to get parts ordered.
markings on tank are:
52102337 . Code 221911. Assy 52102343. MSDB 471. I've tried finding these numbers on the net and Dodge sites but can't cross anything. Any help would be great. Thanks
Old Jul 7, 2010 | 09:47 PM
dodgeramguy85's Avatar
dodgeramguy85
I didnt think 15 was even a option I have 22 I thought the only options were like 22 and 26 or 28(cant remember which)
Old Jul 7, 2010 | 10:36 PM
magnethead's Avatar
magnethead
my 01 clicks around 16.5. Today i put lucas fuel injector cleaner and i looked up and it said 18.5 and i was like "whoa hang on here.." and stopped it before it came out the neck (which it has done before).
Old Jul 7, 2010 | 10:58 PM
Josh Abels's Avatar
Josh Abels
edit: i was wrong only applied to the 01+
ull prolly have to check the owners manual or how much u fill up on a reg basis
but the options on the second gen daks were 15 for older ones, 22 for all, then 24 for the quad cabs
Old Jul 7, 2010 | 11:05 PM
dodgeramguy85
Heck my 78 cj5 has a 12 gal tank and thats in a cj 15 for a truck is small
Old Jul 7, 2010 | 11:15 PM
magnethead's Avatar
magnethead
Then what size would I have..cuz I routinely fill in the 16's, even with fuel light on, today it went to 18.5 and I stopped it, I've had it come out the neck when it didn't click once, i stopped it at 19.75.
Old Jul 7, 2010 | 11:18 PM
Josh Abels's Avatar
Josh Abels
uve got a 22gal, my light comes on at the same time its very common in the daks for it to come on way early, i just pay attention to my tripometer to gauge when i need to fill up, usually 350mi to the tank and fill up ~20gal
and to get rid of the overfilling, mine did it when i first got hte truck, put the nozel all the way in, then just back it out a bit and u should be good
Old Jul 7, 2010 | 11:27 PM
magnethead's Avatar
magnethead
are the tank rating with foam or without foam? Or are our tanks foamless?
Old Jul 7, 2010 | 11:28 PM
00dakSport's Avatar
00dakSport
everytime i fill the tank up when the fuel light comes on it takes 16 gallons. i think i read somwhere you have 5-6 gallons left when the light comes on. i could be wrong.
Old Jul 7, 2010 | 11:29 PM
Josh Abels's Avatar
Josh Abels
foam? the baffle things to keep it from sloshing?
i no mine is a 22gal cause ive filled up 21.5 gal before
00 thats correct, although i dont know why they have such a ridiculous "reserve" prolly cause the mpgs on trucks arent as good
