cant afford any more problems
Old Jul 15, 2010 | 07:34 PM
thunder98110's Avatar
thunder98110
Exclamation cant afford any more problems
yup, dakota playing games with me again.
went offroading and 5 minutes in, i get a horrible noise *see videos*
i know the drivers side tie rod end boot is ripped but i dont think its causing the noise. no pulling while breaking and steering wheel has no vibrations. i think its only in 4x4. first time using 4x4 after changing front diff and tcase fluid.
http://www.youtube.com/watch?v=5F9riM3hgz0
http://www.youtube.com/watch?v=fXyU_1BkJuA
Old Jul 15, 2010 | 10:41 PM
Independentfool's Avatar
Independentfool
wise man says you gotta pay to play. so if you cant afford a breakage then dont beat on it!
anyway, sounds like one of the front axles is not seated all the way in the diff, or you stripped its threads.
Old Jul 15, 2010 | 10:50 PM
dodgeramguy85's Avatar
dodgeramguy85
I would jack up the truck and see if there is any play in those axles
Old Jul 16, 2010 | 10:34 PM
thunder98110
seems like its the front drive shaft, i can rotate it a little and hear that same noise. ujoints look fine though.
Old Jul 19, 2010 | 11:00 PM
dodgeramguy85
so is this noise all the time? If so I would either put it on jack stands(be very careful when doing this) and run the truck see if you can pin point the noise and rack it much nicer when doing this or have someone drive or walk beside while you drive it and try to pinpoint it that way
Old Jul 19, 2010 | 11:28 PM
thunder98110
just when it was in 4x4 i didnt have any problems with it driving back after if first happened and no problems since.
Old Jul 20, 2010 | 12:06 AM
dodgeramguy85
Almost like something in TC is messed up or some part that has lots of torque but I've never heard that noise before. Have you tried out 4x4 again since? its kinda like it wasnt engaged the whole way or something im stumped
