Emergancy Parking Brake assembly Help
Old Jul 17, 2010 | 10:11 AM
vette68's Avatar
vette68
Default Emergancy Parking Brake assembly Help
2003 Dodge Dakota 4x4, 4.7
Can someone send me a link for a picture of the rear emergancy brake assembly.
I'm having problems with re-assembling. Everything seems to be too loose once I have it all together.
Thanks.
Old Jul 17, 2010 | 10:21 AM
Josh Abels's Avatar
Josh Abels
talking about in the drum brakes? invest in a Haynes manual makes it so much easier
Old Jul 17, 2010 | 10:17 PM
KillerKilgore's Avatar
KillerKilgore
http://www.chiltonlibrary.com/conten...9-dako-g09.gif
Old Jul 23, 2010 | 02:13 PM
jnwolf2000's Avatar
jnwolf2000
Sounds like disc brakes with the parking brake inside the rotor. I just changed mine.
The thicker spring goes with the straight section up, and the thin long spring at the bottom under the adjuster.
FYI
The brake material came up glued from the steel, and was making a clicking noise like a bad U-Joint.
james
