Couple questions about '97 Dakota 4X4
Old Jul 22, 2010 | 10:39 AM
Maxx_Magnum's Avatar
Maxx_Magnum
Default Couple questions about '97 Dakota 4X4
Hey guy, I'm a regular over in the 2nd gen Ram section, but I have a buddy with this Dakota who is needing some work done. And guess who gets to do it?
Ok, first question is about the shift cable. The clip that holds it in the bracket down by the trans broke and he currently has it held in with vicegrips. I have a cable here, is it a big deal to change? Anything special I should know when changing it?
The other issue is with his right front cv shaft. It let go in the woods the other day and we limped it here to my place.(talk about some bad noises coming out of it, I could hear it from behind him, over the roar of both our loud trucks!) He picked up a replacement shaft, is this a big deal to change? Will I have to separate the knuckle from the control arms to get the new one in? Any tips here also? And could the truck be driven at all if I pulled the broken shaft out, leaving the splined end in the hub temporarily? Any help is appreciated
Thanks for any help and tips guys!
Old Jul 23, 2010 | 01:09 AM
Maxx_Magnum
no one?
Old Jul 23, 2010 | 11:15 PM
No clue on the cable, but, you more than likely (almost certainly) will have to separate the knuckle from the joints to get the new shaft in. Doesn't sound like it will be too much trouble to get the old one out.......
Old Jul 24, 2010 | 06:09 PM
bpark8824's Avatar
bpark8824
Yeah, you have to seperate the knuckle. I recently did the passenger side cv shaft on mine. Time consuming, but not too hard.
