AC condenser, pressure switch, accumulator
Old Jul 28, 2010 | 02:44 PM
Senate427's Avatar
Senate427
Default AC condenser, pressure switch, accumulator
vehicle- 97 Dakota ext v8 automatic 4x4 140k
Just had the local mechanic shop check my AC for leaks and they said, I have to replace the low pressure switch, condenser, and accumulator. So is it hard to replace all those parts myself? Last month I replaced the radiator, water pump, hoses, and o2 sensor. So would you say it's easier than replacing those parts?
Thanks
Old Jul 29, 2010 | 03:01 AM
dodgeheller99's Avatar
dodgeheller99
they are easy, you just need to get the special disconnect tools, just make sure you have new O-rings.. or buy they cheesy DVD from autozone that walks you through everything i learned alot from it
