M1 intake install
Old Jul 28, 2010 | 08:51 PM
dodgeheller99's Avatar
dodgeheller99
Default M1 intake install
hey guys i was lucky enough to get my hands on a true M1 intake for my 5.2L
i have already done the intake manifold on this truck to fix the belly gasket so i know how do to the job.
so here is my question, is there anything else i need? do i need new or special manifold bolts?, are their any clearance issues. and does the throttle body easy just bolt on to the top? it also came with an adapter plate of some kind for the top, do i need/ what is this?
Old Jul 28, 2010 | 09:16 PM
wink2873's Avatar
wink2873
its pretty much the same as when you fixed the belly pan gasket. Im not sure about the tb, just take it off the truck and try to mount it on the intake with the adaptor and see if it will work... you shouldnt have clearance issues.
Old Jul 28, 2010 | 11:23 PM
lastrights's Avatar
lastrights
you may need TB adaptder and some other stuff , do ya got some pics so we can see what your working with ?
Old Jul 29, 2010 | 06:19 AM
dodgeheller99
i can get some pics up later today. it is an actual Mopar M1 though.
what can i expect as power and MPG? technically if it gives me more power without changing anything else but the intake it should give me more MPG right?
