Coolent/Overheating from overflow!
Old Oct 12, 2010 | 08:02 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I hate to be the bearer of bad news but it sounds like you have a warped head. The gaskets used now are multi-layer steel. The days of the "blown head gasket" and the usual "symptoms" are over. That is classic symptom from the last few i've done....which is, happens after long drives. The head has to get superheated before that weak spot opens up enough to overcome the engines cooling ability. The longer you go without fixing it, the more frequent your overheating spells will be.
Originally Posted by Tugboat
I'll post when I hear from the dealership on what the actual problem is..... last time there answer was well whatever it is isn't gonna fix it self just drive it until the problem is clear to them...... That to me is unexceptable ......
They may be reluctant to tell you what I just did because it sounds like hoooey.
