Pros/Cons of Dumped/side exit exhaust setups
Old Aug 18, 2010 | 04:19 PM
SpencerS's Avatar
SpencerS
maybe with like a diesil or high output 5.9 or a older carbeurated engine in rare cases.
The 4.7 doesnt even run close to that hot let alone the 3.9 v6.
The only heat issue that can cause a blow out is if your breaks are seizing.
Old Aug 18, 2010 | 06:25 PM
thunder98110's Avatar
thunder98110
Originally Posted by RPMRamFury
The only issue with side dumping before the rear tire is that over time if you are going down the interstate, with it close to your rear tire, it can heat it up and blow out if it gets too hot. Ive seen it happen.
maybe if you ran the pipe nexto the tire but i cant belive the exhaust gas could do that. ive driven 10hrs straight with no problems.
Old Aug 18, 2010 | 07:58 PM
00dakSport's Avatar
00dakSport
Originally Posted by Rantz
. My current chrome tip has faded and isnt shiny anymore. Is there a way to revamp it and bring its luster back to life? I mean, come on! The shiny tip has got to give me at least 10hp! lol
my tip was covered in surface rust. i used turtle waxs bug and tar remover with a paint safe scrudding pad. after that just buff it with a dry cloth till its shiny again.
Old Aug 18, 2010 | 09:15 PM
metalsrfr's Avatar
metalsrfr
I just recently changed my whole exauhst setup I haven't had a chance to get pics up yet though been busy with work but anyways I have side pipes with glass packs on my 5.9 and surprisingly its not that loud unless I'm wot . Performance wise I lost some of my low end torque but I have made up for it in the mid and high range haven't had a chance to get it to the track due to needing bushings and balljoints but to and from work I have noticed the change in power and I trully believe it has leveled it out accross the power bands. And it looks nice too I get compliments on it constantly in the last 2 weeks since I have had them on there .
Old Aug 18, 2010 | 10:11 PM
Hahns5.2's Avatar
Hahns5.2
IMO, dumped exhaust sounds like crap, at least inside the cab, it's all noise and no tone..
My favorite exhaust is side exit, looks and sounds great.
Old Aug 19, 2010 | 12:17 AM
Rantz's Avatar
Rantz
I do also have a quad cab. I wonder if it would bother a passenger who would be getting in and out near it. Not that I have passengers back there that often though. Usually it's just me and the wife when she doesn't insist on taking her Puh Puh Puh Prius lol
I have decided that I am definitely not interested in going dumped. I did it before and liked it when I was in high school, but I have to admit, it did get annoying on long drives. I think I'll look into a polish for my chrome tip and see if that makes me feel better for the time being. Otherwise I'll look into getting it swapped to a side exit, but I'll be sure to keep it clear of the rear tire if I do. I have a pretty informed enthusiastic shop that I go to for exhaust and I think they would be able to weigh in on the concept.
Thanks for the input guys!
