what is goin on with my power steering pump
Old Aug 27, 2010 | 03:57 AM
norbybmx's Avatar
norbybmx
Default what is goin on with my power steering pump
So my original pump went out 2 weeks ago, and the one i put in just went out. dose any one know why this might be. my high pressure hose started leaking too. and my pressure switch is broken too. im changing my pump tomorrow for the second time. but dose any one what could be the cause of my pump failing?
Old Aug 27, 2010 | 01:40 PM
SpencerS's Avatar
SpencerS
replace the power steering lines, and check the mesh inside the reservoir to see if its broken.
Old Aug 31, 2010 | 05:07 PM
norbybmx's Avatar
norbybmx
the resovor is fine i replaced the pump again, and the high preasure hose, and now my pump is starting to leak again. there is also alot of air in the system.
