no fuel
Old Aug 30, 2010 | 12:47 PM
dakota19762's Avatar
dakota19762
Exclamation no fuel
I swapped out my 3.9 for a 5.9 this weekend, now I cannot get a signal from the gas tank/ fuel pump. Nor do I get a spark. What have I done wrong? I switched out the PCM and I still get nothing with the old PCM. Only changes to the wiring was the 7 & 8 injectors. I need help fast!
Old Aug 30, 2010 | 08:35 PM
dodgeramguy85's Avatar
dodgeramguy85
Fuel: Pump relay
Spark: Could be bad crank positioning sensor
Old Aug 30, 2010 | 09:22 PM
McNasy's Avatar
McNasy
did you switch out the bcm and ecm as well. the pcm is (powertrain control module), the transmission computer.
Old Aug 31, 2010 | 03:49 PM
dakota19762
It seems that when you put in the motor, you would be wise to remove the crank sensor. In my excitement (and because I had to do it by myself) I sandwiched the crank sensor between the block and trans. Thus, truck is unhappy. I will get it fixed tomorrow and hopefully I'll be happy with that monster of a motor
