fuel injectors
Old Sep 17, 2010 | 09:00 AM
tattoodbrute's Avatar
tattoodbrute
Default fuel injectors
does anyone know if the injectors are the same for the 3.9 as the v8's can't find any used v6 ones so maybe better luck with the 8's
Old Sep 17, 2010 | 04:40 PM
dakota19762's Avatar
dakota19762
5.2 is the same. 5.9 are bigger
Old Sep 18, 2010 | 05:35 PM
CHBGator's Avatar
CHBGator
New here but I read somewhere on another site that there are a few parts including injectors that will cross over from the 5.2 to the 3.9 since the 3.9 is basically a 5.2 with two cylinders sawed off. Not literally of course...
Old Sep 18, 2010 | 11:45 PM
cowboy63645's Avatar
cowboy63645
There are a few sets on ebay right now, used, and there are a few new sets on there as well for the 3.9. If you would rather have new, these are fairly resonable http://www.fiveomotorsport.com/fuel-injectors/dodge/ Bosch 0280155934
Old Sep 19, 2010 | 07:14 AM
bwdakrt's Avatar
bwdakrt
Depending on the year model. Pre '00 injectors have the retangular shaped connector and the '00+ have the oval shaped connector. Regardless of the engine size, whether it's the 3.9, 5.2 or 5.9, the injectors are all indentical and will interchange as long as you have the right shaped connector for your year model.
Old Sep 20, 2010 | 08:47 AM
Blaze10's Avatar
Blaze10
i dont wanna jack this thread and i didn't wanna fill the forum up with another thread, but if i may, how do you check to see if you have bad fuel injectors ?
