Will my exhaust fit
Old Sep 19, 2010 | 12:09 PM
briankeith1968's Avatar
briankeith1968
Question Will my exhaust fit
I HAVE A GIBSON SUPER TRUCK EXHAUST I BOUGHT THAT CAME OFF A DODGE RAM 1500 4.7 ENGINE.
PROBLEM I HAVE IS MY TRUCK IS A DAKOTA QUAD CAB WITH A 4.7 ENGINE.
CAN I GET THIS EXHAUST TO FIT MY DAKOTA AND WHAT PROBLEMS WILL i RUN INTO WHEN TRYING TO INSTALL.... MAYBE A SPACE ISSUE .
THANKS FOR ANY AND ALL INPUT.
BRIAN IN CORAL SPRINGS FLORIDA
Old Sep 19, 2010 | 12:15 PM
thunder98110's Avatar
thunder98110
is it a full system or just a muffler?
Old Sep 19, 2010 | 12:17 PM
briankeith1968
just the muffler and tips that exit the side behind the rear door
Old Sep 19, 2010 | 12:28 PM
thunder98110
i dont know what or if there is a difference from the ram frame to the dakota. if there is you could always just cut off the existing tips and get them welded to the right position.
Old Sep 19, 2010 | 12:32 PM
briankeith1968
someone told me that was the problem the tips would be extending out from the truck way to far.
Thank you
Old Sep 19, 2010 | 12:35 PM
briankeith1968
Default exhaust picture
here is the exhaust I am trying to put on the Dakota.
Old Sep 19, 2010 | 12:37 PM
thunder98110
well do a test fit, see if there is room.
Old Sep 19, 2010 | 02:59 PM
cowboy63645's Avatar
cowboy63645
cut the tips off, and the cut how ever much pipe you need off the back of the muffler, re-weld and your done.
Old Sep 19, 2010 | 05:26 PM
TheePlaymaker's Avatar
TheePlaymaker
hangers might be the issue i'm sure if you took it to a good shop they could get it to fit, however the dakota frame hangs low so i'm not sure how it will look
Old Sep 19, 2010 | 05:35 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Have you ever had a vehicle with side exhaust? It can get VERY annoying at times. Just a thought.
