roaring noise
I have a 2000 Dodge Dakota with 220 k. Just started having a roaring noise, almost as loud as mud tires. Seems to be coming from the front. Engine runs fine, no panel lights. Just had new bearing and seals in rearend, but like I said, the noise seems to be coming from the front. The noise does not change with acceleration or braking. Any ideas?
Thanks for any suggestions...
So it's there when sitting, accelerating or braking?
IF it's there in park/not moving, that rules out a wheel bearing
IF it doesn't change with engine speed, rules out the clutch fan
Next, put it in neutral and coast with the engine off.
IF it's still there, then it's something in the driveline
IF it goes away when you shut the engine off, we can start narrowing in that direction.
The noise happens only when the truck is moving. I did jack the front end up and tried to move the tires from side to side and top to bottom, but does not have any play either way. If it is the bearings, wouldn't it have some movement? I also noticed other post indicating that if they turn left or right that the noise would go away. This is not the case with my truck. The noise does not change with speed either.
With nobody around you on a good, clear road (might be hard to find), put the trans in neutral and shut the engine off.
If the bearings seem to be good, I'm running out of ideas.
So once you start moving, it's there, but never changes, until you come to a stop?
It only roars when the truck is moving.
That rules out engine issues as the engine is running when you are not moving & it isn't roaring.
I'm going to go out on a limb & say wheel bearing. It may be a CV joint - but I'm guessing wheel bearing.
modern perminantly sealed bearings dont' have to have play when worn out. The weight of the truck isn't really suspended by the bearing as it is on old bearings so when they go bad the wheel may not be loose.
It usually has a speed sensative sound, but if it is really bad it will scream just as loud at slow speed as it will at high.
