p0300,p0302,p0308 has anyone found a solution to these.
Old Sep 29, 2010 | 05:07 PM
metalsrfr's Avatar
metalsrfr
Default p0300,p0302,p0308 has anyone found a solution to these.
Ok so for the last 2 weeks my r/t has had this wonderful cel been checking plugs wires injectors cap and rotor cam shaft pos sensor tps . So now I'm wondering after searching a lot on here and not finding awnsers has anyone figured this problem out yet. I have checked everything I can think of and that any of the other posts on this have suggested has anyone figured this problem out?
Old Sep 29, 2010 | 07:47 PM
zanethan's Avatar
zanethan
what do those codes mean? If its bank 1, catalyst inefficiency, and misfire in a cylinder then its probably a bent valve or cracked head.
Old Sep 29, 2010 | 07:59 PM
magnethead's Avatar
magnethead
300- random misfire
302- #2 misfire
308- #8 misfire
Old Sep 29, 2010 | 11:14 PM
metalsrfr's Avatar
metalsrfr
Yeah I already thought about a burnt or bent valve but if that is the case wouldn't the problem be more consistent rather than here today gone tommorow it seems to do it when I don't let the truck warm up enough to its standard and not mine and the weather has changed considerably.
Old Sep 30, 2010 | 12:18 PM
zanethan's Avatar
zanethan
yeah it would be there all the time. but it could be a head gasket going bad that leaks when it's cold and then seals up as it expends.
Old Sep 30, 2010 | 12:47 PM
metalsrfr's Avatar
metalsrfr
now that does make some sense zanethan , how could you tell w/out having to pull the head off ? if it wasnt my daily driver i wouldnt have any problem pulling it but being in the army and it being my dd i dont have that kind of time.
Old Sep 30, 2010 | 02:36 PM
zanethan's Avatar
zanethan
Maybe a compression test would give you some better answers I really have no clue how to test it other than that though.
