exhaust question
Old Oct 1, 2010 | 12:44 PM
midget-farms's Avatar
midget-farms
Default exhaust question
I will need a new mufler sometime in the next 6 months. I've seen all the youtube vids & I have not yet decided on what muff I want to install, but I think I know how I want the pipes routed.
I'd like duals that exit in front of the rear wheels. Maybe a twin tip on each side.
My question is this - the fuel tank sits on the drivers side inside the frame rail - will running an exhaust pipe under this tank cause problems? Can you install a heat sheild? or insulation or something to prevent heating the fuel or the poly tank?
That is the only part that bothers me - I don't need a hole melted in my tank & then spill 20 gals of gas on a 1000 degree tail pipe.
Old Oct 1, 2010 | 12:49 PM
thunder98110's Avatar
thunder98110
just use some tin foil to cover the gas tank, or use heat wrap on the exhaust.
Old Oct 1, 2010 | 01:03 PM
metalsrfr's Avatar
metalsrfr
Or you can go with oldschool side pipes like mine and not have to worry abou it . Just think old school corvette they look awesome too that of course depends on if you're going to be going offroad.
Old Oct 2, 2010 | 07:15 PM
midget-farms
Cool idea - but not really what I'm looking for. I like the idea of heat wrap though - or some type of heat shield under the gas tank.
