Remote program
Old Oct 1, 2010 | 11:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default Remote program
STANDARD PROCEDURE - RKE TRANSMITTER PROGRAMMING
New Remote Keyless Entry (RKE) transmitters can be programed using the DRBIIIŽ scan tool and the proper Diagnostic Procedures manual, if no functioning transmitter is available. The DRBIIIŽ scan tool can provide confirmation that the PCI data bus is functional, and that all of the electronic modules are sending and receiving the proper messages on the PCI data bus.
The following procedure can be used as long as one functioning transmitter is available:
Turn ignition to the RUN position (allow ignition chimes to stop).
Using any original (working) transmitter, press the UNLOCK button for 4 to 10 seconds.
Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and press the PANIC button for 1 second, and release both buttons. A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
Press LOCK and UNLOCK buttons simultaneously for 1 second and release.
Press and release any button on the same transmitter and a chime will sound, or locks will cycle after successfully programming the transmitter.
Repeat steps 5 and 6 to program additional transmitters.
Turn ignition to the OFF position. Transmitter programming mode will discontinue after 30 seconds. All transmitter programming must be completed within time specified.
Old Oct 4, 2010 | 02:23 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Great post. I will post this in the FAQ.
