rear sway bar bushing size
so my rear sway bar and front are shot, but im only going to do the rears
now. i dont know the size for the bushing. is it 16 or 20 mm?
i found some moogs both the links and bushings...
I don't understand why some would be 16 and some 20. I could see if one was 4wd and the other was 2wd, but other than that how do they decide? I also need replace my sway bar bushings. Where did you find the moog ones thunder?
I have a caliber and will measure it tomorrow.
after about and an hour searching, i was going to go with partstrain.com for 97 bucks but i checked rockauto, and its only 60bucks!
here are the part numbers
MOOG Part # K3160
MOOG Part # K80244
i bet i have the 16mm its pretty small. i also found that one of my bump stops was completely gone, lol
MOOG Part # K3160
MOOG Part # K80244
and thunder u suck on the interwebs i found this in three seconds lol
http://shop.advanceautoparts.com/web...SAMS_715278830___
Trending Topics
but they can make into a trick tuning deal if you unhook the rear to loosen the back end up a little. I'm debating unhooking my rear because I'm constantly lifting a tire.
