Air preassure question
Old Oct 12, 2010 | 12:55 PM
dodgetrinket's Avatar
dodgetrinket
Default Air preassure question
I know this is kind of a noob question, but I want to be more secure about this. What air pressure should I be using on my front and back tires? these are the numbers on my tires P245 70R16
Old Oct 12, 2010 | 12:58 PM
thunder98110's Avatar
thunder98110
40psi max i think. ive got the same size tires as you. 35 is what most people use on here.
Old Oct 12, 2010 | 12:59 PM
dodgetrinket
Morning Thunder, I was thinking 34, but I'll make sure I have 35 in the four of them, thanks for the quick answer
Old Oct 12, 2010 | 01:01 PM
thunder98110
i thought u had the 4.7? not the 3.9?
saw your editted post from yesterday. nvm
Old Oct 12, 2010 | 01:10 PM
dodgetrinket
Yea, I am still missing some info on the truck since I got it like 2 days ago so this morning while I was getting my tags paperwork ready I saw the info, and updated it in my signature too.
Old Oct 12, 2010 | 07:51 PM
midget-farms's Avatar
midget-farms
The tire sidewall says the max pressure - Different rated tires will have different pressures. For example a load class C tire is max 35 psi but a load class E tire has a max of 90psi.
Just look on the sidewall & it will tell you the pressure to run.
Old Oct 12, 2010 | 10:58 PM
dodgetrinket
Thanks midget, I added 35psi on each today and went for a test on I-55 at 80mph hehe it runs smooth
