Code won't go away!
Old Oct 18, 2010 | 09:01 AM
billlesmerises's Avatar
billlesmerises
Default Code won't go away!
I have a 98 dakota with the 5.2 4wd. I have owned it for 3 years and about every 6 months I get a code of 1899. I know it has something to do with the neutral safety switch ( I think). I can clear the code and then it will be fine for around 6 months. Any help or suggestions, would be appreciated.
Old Oct 18, 2010 | 11:41 AM
dodgeramguy85's Avatar
dodgeramguy85
Did you ever get a new switch? I think they are about 20.00 for them. Most of the time when a code comes up is because there is a fault with a item so im guessing that your switch is going bad or the wiring to the switch is shorting out or something
