drivetrain vibration...
Old Oct 20, 2010 | 05:16 PM
Mxztnt640's Avatar
Mxztnt640
Default drivetrain vibration...
I have a '99 dakota 5.2L 4x4. I have a vibration that I cannot find the source of. It starts around 15mph and continues to get worse until around 50mph then tapers off as I get to highway speed(70mph+). I have checked my wheel bearings and they are fine. Removed the front and rear shafts and all U-joints are good and they have no play when they are installed. I noticed driving with the front shaft removed it is less amplified. There is a slight vibration in the 4x4 selector but no more than usual. I have put the truck in neutral and slowly brought rpm's up to 3k(so its not the torque converter)...
I can feel it in the steering counsil and the floor boards. Sounds like it is coming from the rear but feels like its in the front end. Thanks in adv.
Old Oct 20, 2010 | 05:56 PM
Mxztnt640's Avatar
Mxztnt640
I should add that I have put it in neutral while on an off ramp and it still vibrates. Also if I take a hard right turn it goes away until I begin to straiten out the steering wheel.
Old Oct 21, 2010 | 03:23 PM
midget-farms's Avatar
midget-farms
I would guess its your tires. You may have a broken belt on one of the tires - check for lumps or tread that is seperating.
Sounds funny - but I've had tires that look new that nearly pulled me off the road before.
Old Oct 22, 2010 | 08:28 AM
Mxztnt640's Avatar
Mxztnt640
I work @ a tire shop and my tires couldn't be any more perfectly balanced...
Old Oct 22, 2010 | 09:41 AM
midget-farms
OK then -
Here is a list of things that will cause a driveline vibration.
1. Adding lift to the truck. - Extreme drive shaft angle will shake like a belly dancer - ask any Jeep guy - shouldn't be an issue on a Dakota unless youve gone up more than 4".
2. Bad tie-rod ends - since you work at a tire shop I assume they can do allignments & you have checked this.
3. Drive shaft out of ballance - there are weights welded to the shaft in spots to ballance it - if these are knocked off it will vibrate
4. wheel bearings front or back
5. bad shocks - once a wheel starts to bounce its hard to stop it w/o shocks - if one is broken or worn you will feel it.
Other than that I wouldn't know.
Old Oct 22, 2010 | 02:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
This post will help. https://dodgeforum.com/forum/1947777-post6.html
