truck stalls when stopping
Old Oct 29, 2010 | 11:08 AM
snowx228's Avatar
snowx228
Default truck stalls when stopping
truck runs great untill it idles down and often stalls but starts right up when i turn the key what will cause this
1999 sport 318 5 speed.. cold air intake thrusch turbo exuast
Old Oct 31, 2010 | 10:01 AM
Derek2002's Avatar
Derek2002
Try cleaning your IAC.
Old Oct 31, 2010 | 07:09 PM
olsarge's Avatar
olsarge
Low transmission fluid will cause the torque converter to lock up and it can't idle.
Old Oct 31, 2010 | 07:11 PM
olsarge's Avatar
olsarge
Never mind Just saw it is a 5 speed.
Old Oct 31, 2010 | 09:30 PM
spshultz's Avatar
spshultz
If it's wanting to stall when you're coming to a stop (and cleaning the IAC doesn't seem to help) maybe it's the Vehicle Speed Sensor.
Old Nov 1, 2010 | 02:13 PM
ronditri's Avatar
ronditri
Check the battery. If the voltage is low the first thing the computer eliminates is the idle circuit. I had the same issue and a new battery solved it.
Good luck
