will not idle
Old Nov 28, 2010 | 05:21 PM
ph98223's Avatar
ph98223
Default will not idle
My 2000 dakota qc w/4.7 will not idle i have replaced the tps and cleaned the tb there is no codes i have searched the threads and cannot find any help could it be crankshaft sensor it has me really confused since there is no cel at all, any help will be apreciated
Old Nov 28, 2010 | 05:40 PM
FireFighterHill's Avatar
FireFighterHill
You missed the IAC valve. It controls the idle of the truck and can become clogged with carbon build up. Will it stay started if you keep your foot on the gas and keep it at 750rpm?
Old Nov 28, 2010 | 05:46 PM
ph98223's Avatar
ph98223
yes it will stay running with foot on the gas and were is the iac valve
Old Nov 28, 2010 | 06:18 PM
FireFighterHill
yours should look like this http://i38.tinypic.com/vp83h2.gif
Old Nov 28, 2010 | 06:25 PM
FireFighterHill
And by the way if you have the money id also replace the MAP sensor while your at it. It can help fuel mileage and I believe it may help with the idle as well.
Old Nov 28, 2010 | 08:24 PM
thunder98110's Avatar
thunder98110
on the 4.7 the iac is on the right side of the TB there will be to sets of sensors the top is the TPS the bottom is the IAC, you cant miss it.
Old Nov 29, 2010 | 11:38 AM
ph98223's Avatar
ph98223
thanks for the info i will look for it tonight when i get home and again thanks
Old Dec 9, 2010 | 04:27 PM
roger197k's Avatar
roger197k
Default Will not idle
Have same symtons as ph98223 but on 2000 Dakota 3.9L. Will start, but will not maintain idle (stops) when cold. Will run if foot is kept on gas peddle. Would changing Idle Air Control motor cure my problem on the 3.9L? Battery was changed last month, same problem when cold outside.
Old Dec 9, 2010 | 05:23 PM
United's Avatar
United
I had this exact same problem not too long ago. After checking my TPS and MAP sensor and replacing my IAC, I found out that it was actually the battery that was causing the issue. I popped in a new battery and I haven't had a problem since. If I were you, I'd go to Advance or somewhere like that and get the battery checked before you go shelling money out on sensors.
Old Dec 9, 2010 | 05:30 PM
ph98223's Avatar
ph98223
I will go have the battery tested. But for some unkown reason it has started to run fine now with only changing the tps. IDK it is a mystery to me.
