choke/stalling out, air fuel adjustments???
Old Dec 1, 2010 | 09:11 PM
kuzzy's Avatar
kuzzy
Default choke/stalling out on replaced 5.2l
Hey guys i just replaced the engine on my 99 dak 5.2 4x4 and there one thing that i cant figure out..
Here whats up.. idles great, driving good. but when i start off, shift to drive and hit the gas there a small delay and then starts moving... sometime when warmed up, it will just stall out. under the hood i was playing with the TB and when i hit the gas the engine just about dies for a sec and then catches up.. maybe short of fuel or air?? what do u guys think?? vacuum hose, fuel injector no idea...
let me know if you guys need more info
thanks
Old Dec 1, 2010 | 09:13 PM
kuzzy's Avatar
kuzzy
i dont know if this would be of use.. but the engine i put in is a 5.2 ram engine in the dak now
Old Dec 1, 2010 | 09:59 PM
dodgeramguy85's Avatar
dodgeramguy85
I would say the tps is bad but before you get one pressure test to see if you are getting enough fuel I want to say 45psi at idle but Im having a hard time remembering lol
Old Dec 2, 2010 | 10:13 AM
kuzzy's Avatar
kuzzy
i switched over the TB from my old 5.2 and still same story..
Old Dec 3, 2010 | 02:16 PM
kuzzy's Avatar
kuzzy
bump
anything else it can be besides fuel pump issues
Old Dec 3, 2010 | 02:24 PM
dhvaughan's Avatar
dhvaughan
sounds like a vacuum leak. to prove it, temporarily plug off all ports to the manifold. caution - you might not have power assist brakes and your transmission might not upshift with vac lines disconnected.
