Need Fog housings
Old Dec 14, 2010 | 09:04 PM
magnethead's Avatar
magnethead
since you said yours was cracked on the inside only, i took mine and filled them with water.
The one that didn't take on water? Cracks are inside only.
The one that did? You ca't feel the cracks from the outside, but it looks like a shower head when i fill it with water. So that mystery is solved.
Old Dec 14, 2010 | 09:07 PM
thunder98110's Avatar
thunder98110
yeah i cant feel anything from the outside.
Old Dec 14, 2010 | 09:13 PM
magnethead's Avatar
magnethead
thats why i checked. apparently you dont have to :/ But I really don't wanna spring $120 for a new pair, plus $70 for the HID's and pigtails
Old Dec 14, 2010 | 09:15 PM
thunder98110
might as well buy a set of piaa fogs, like me.
http://www.andysautosport.com/dodge/...a00088042.html
Old Dec 14, 2010 | 09:20 PM
magnethead's Avatar
magnethead
Here's what I'm gonna do-
$ ??- pair of housings
$ 42- 35W HIDS http://www.mydepots.com/normal-hid-k...-beam-p-1.html
$ 21- Relay kit http://www.mydepots.com/relay-harnes...-kit-p-24.html
$ 7- pair of 880-898 connector male pigtails http://autolumination.com/connectors.htm
I'm gonna take the factory fog wire, use the pigtails to convert them to wire leads, and connect them to my 55W driving lamps. The i'm going to use that relay kit, and use the switch I added on my dash to turn the HID's on and off. That way I can have HID, driving, and lows, or HID and highs. Not sure what my illumination distance will be, but I can bet I'll be able to see things!
Old Dec 14, 2010 | 09:38 PM
magnethead's Avatar
magnethead
72 for a pair, not so bad.. http://cgi.ebay.com/ebaymotors/NEW-P...Q5fAccessories
Old Dec 29, 2010 | 08:43 PM
NorDakota's Avatar
NorDakota
Would it be possible to drill like a 3/32" hole in the bottom backside of the housing so any water could drain out?
