wrecked my truck (kinda...w/ pics)
Old Dec 16, 2010 | 08:47 PM
  #41
magnethead's Avatar
magnethead
Drove it on the interstate tonight. Wheel is off to the left a little, but it doesn't wander or shake, so it may have been that way prior. I did a few brake stabs, and it takes alot of effort to get the backs to lock up. I did happen to get cut off though, and both backs locked before either fronts did, and it stayed nice and straight.
Old Dec 16, 2010 | 08:57 PM
  #42
dodgeramguy85's Avatar
dodgeramguy85
So you think its way better than before?
Old Dec 16, 2010 | 09:44 PM
  #43
magnethead's Avatar
magnethead
I wouldn't say it's way better, but it's an improvement on dry ground. We'll see about wetness.
To pull the dash bulbs, you have to pull the cluster correct? There's a panel above the steering column, so I can't just reach up like I could on the old dually.
Old Dec 16, 2010 | 09:55 PM
  #44
dodgeramguy85
I have the old dash but for me its pull the dash bezel and 4 screws and the cluster is out.
Old Dec 16, 2010 | 10:05 PM
  #45
magnethead's Avatar
magnethead
There's enough of a pigtail, I take it, to pull the cluster out without unhooking things?
Old Dec 16, 2010 | 10:09 PM
  #46
thunder98110's Avatar
thunder98110
for the 01, to remove the gauge;s you need to remove the dash piece. its just held in by clips. and there are the wires to the airbag, ac controls.
Old Dec 16, 2010 | 10:15 PM
  #47
dodgeramguy85
If I remember right there wasnt a pig tail its just like a connector that sticks out from the cluster and the back of the dash so when you pull it out it just unplugs kinda hard to explain
  #48
magnethead's Avatar
magnethead
so same as doing the radio, then just unscrew the cluster itself?
Old Dec 16, 2010 | 10:19 PM
  #49
thunder98110
4 screws and just pull it out. no pigtails. just a male and female connectors on the back that detach once u pull.
