No heat?
Old Dec 16, 2010 | 02:43 PM
Zemandude's Avatar
Zemandude
Default No heat?
Got my 1999 Dakota, just now starting to have to use heat, and it doesnt get warm, barely warmer than the cab, any suggestions why that could be??? im 17, fairly new to trucks, any help would be greatly appretiated
Old Dec 16, 2010 | 03:40 PM
dodgeramguy85's Avatar
dodgeramguy85
Try flushing the heater core first. It made a big difference on my truck.
Old Dec 16, 2010 | 06:24 PM
Bam-Bam's Avatar
Bam-Bam
I had the same problem, I flushed the heater core and radiator, then replaced the thermostat. But it turned out to be something I found in a post, the hoses on the heater core had been put on wrong, I switched the top hose to the bottom and vice versa and bingo now I have lots of heat ! Here is the post I found my info on if you wanna look http://www.dodgedakotas.com/boards/v6/10359.html
Old Dec 16, 2010 | 06:50 PM
KillerKilgore's Avatar
KillerKilgore
https://dodgeforum.com/forum/2nd-gen...y-virused.html
Old Dec 16, 2010 | 07:04 PM
Zemandude's Avatar
Zemandude
alright thanx yall so much, ill try flushing the heating core this weekend.
Old Dec 18, 2010 | 12:52 PM
Zemandude's Avatar
Zemandude
hey yall just wanted to let u know i cleaned out the heating core and now it blows hot!!!
only saying cause i know yall r losing sleep over it thanks for the help guys.
Old Dec 18, 2010 | 12:56 PM
dodgeramguy85
If it was that bad you might to do a whole engine flush might be more crap in the rad.
