99 dak, 3.9L antifreeze leak, need some help...
Old Dec 22, 2010 | 07:09 AM
jamoka3's Avatar
jamoka3
Question 99 dak, 3.9L antifreeze leak, need some help...
I noticed that i have a small antifreeze leak and it looks like its coming from the heater bypass tube from the water pump (located on the drivers side) Its a black metal tube and it looks like it pushes into the water pump and then held in place by one bolt. I wanted to know if I should replace the whole part or just remove it and rtv seal it? The leak is only when the car sits in my drive way and it does NOT leak while its running... any suggestions?
Old Dec 22, 2010 | 12:47 PM
Motorbreath's Avatar
Motorbreath
That tube just pops right out. It seals with a thin O-ring. When I was replacing my water pump a few months back I saw that tiny O-ring and went to replace it with a larger one I had on hand, well the clearance inside the water pump is minimal, so that's why it came with a thin O-ring. I did exactly what you mentioned, and just added some RTV and haven't had any issues. It seems like a weak place in the cooling system, and a great place for leaks to start. That was why I felt the need to do something to it. I believe the tube is just held into place with a tab and a bolt, but gravity will make coolant flow out of the water pump once you remove it, so be prepared.
