Changed tire size, should it make it ride so rough?
Old Jan 2, 2011 | 11:09 AM
cowboy63645's Avatar
cowboy63645
That is a very good point, and one I didnt think of last night. The stiffer side walls make a HUGE difference, especially in a new tire. Check the air pressure, and put them at whatever the sticker says too, and see if that helps. As the tire "breaks in" the ride should soften slightly.
Old Jan 2, 2011 | 11:13 AM
dodgeramguy85's Avatar
dodgeramguy85
I have 32/1150/15 on my truck and its a little bit different than my 31's that I had on before. I run 35-36 in my tires
Old Jan 2, 2011 | 11:18 AM
JDakota92's Avatar
JDakota92
Your old tires were a "P" rated, 4-ply tire. Your new ones are "LT" rated and are a 6-ply tire design. So yes, the new ones will ride stiffer. I wouldn't run any higher air pressure than 35psi. Unless you have a heavy load, the tires will take up to 50psi. By the way, I had the Uniroyal Liberator's on my '93, and they rode great. Loved them.
Old Jan 2, 2011 | 07:00 PM
cycodude's Avatar
cycodude
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
OK, I've dropped them to 35 and 40 per the sticker. We'll see if that helps. If not, I am definitely going to have the balance checked somewhere other than where they were done originally!
Old Jan 2, 2011 | 07:43 PM
jnjinfla's Avatar
jnjinfla
Balance would not be an issue unless you were feeling a vibration in your butt (rear) or steering wheel (front.) I am running Michelin 31's on my 92. I keep my pressures at 35 front 33 rear and am getting even wear. I would recommend that you drop your pressures even further to something around mine. I raise mine to 35 front 40 rear when I tow. As someone else said going to 31's are 6 or even 8 ply tires. They will run a little rougher that 4 ply tires.
Old Jan 3, 2011 | 11:33 PM
cycodude's Avatar
cycodude
OK, they're still at 35 and 41. Haven't had a chance to get out on the freeway yet, but my trip to work seemed a little smoother today! Thanks everyone...
Old Jan 3, 2011 | 11:50 PM
cowboy63645
Glad that you got it figured out and the ride is a little smoother for ya.
