Sway Bar Q's?
Old Jan 21, 2011 | 04:32 PM
wingerak92's Avatar
wingerak92
Default Sway Bar Q's?
Good afternoon,
I am looking to find a replacement set of sway bar bushings as my stock rubber ones are finally squeaking. I found some on Energy Suspensions' Catalog, but it says it's for a 35mm Sway Bar only.
I have a QC 4x4 and was under the impression that there were two different sizes of sway bars?
Any input?
Old Jan 21, 2011 | 04:36 PM
thunder98110's Avatar
thunder98110
https://dodgeforum.com/forum/2nd-gen...pic-heavy.html
Old Jan 21, 2011 | 04:43 PM
wingerak92's Avatar
wingerak92
Thanks!
That's a good write up, except I am looking at my front sway bar.
Old Jan 21, 2011 | 04:55 PM
thunder98110
oops, front you say? no problem:
https://dodgeforum.com/forum/diy-do-...geeteeohh.html
Old Jan 21, 2011 | 05:18 PM
jondakotaguy's Avatar
jondakotaguy
Nice work up.. I actually want a better Sway bar.. the stock has way too much play.. needs a stiffer one.. for better stabilization.
Old Jan 21, 2011 | 05:29 PM
thunder98110
hellwig sells one, i think its around 200 bucks.
http://www.andysautosport.com/dodge/...on/sway%20bars
Old Jan 22, 2011 | 08:52 AM
wingerak92's Avatar
wingerak92
Thanks, I can't find bushings for the life of me though. They all say 35mm or 15mm. Im sure the smaller one is the rear, but I heard that the CC and SC had different front sway bars and I can't find bushings that say QC
Old Jan 22, 2011 | 08:55 AM
wingerak92's Avatar
wingerak92
Of course, the Prothane ones you used only go up to the 2001 Model Year.
Old Jan 22, 2011 | 10:06 AM
bpark8824's Avatar
bpark8824
You need to measure your sway bar. The sizes don't necessarily go by model. Get a caliber and measure it.
