Dak got a color change this weekend!!!
Old Jan 25, 2011 | 02:27 PM
  #41
bpark8824's Avatar
bpark8824
Yeah you can zoom way in. Its just photobucket downsizing it.
Old Jan 25, 2011 | 08:17 PM
  #42
00dakSport's Avatar
00dakSport
i had the same problem with photobucket. if you post the direct link you can click on that and then click on the pic again to get a bigger resolution. like this http://i39.photobucket.com/albums/e1...t/100_2018.jpg
Old Jan 25, 2011 | 11:44 PM
  #43
dodgeramguy85's Avatar
dodgeramguy85
Well took a couple pics wasnt really into it tho, was crappy out and my truck wasnt clean. Ill get some better ones up when it gets nicer out
Old Jan 26, 2011 | 12:07 AM
  #44
Blaze10's Avatar
Blaze10
looks wonderful dude, i am thinking of doing myn as well
Old Jan 26, 2011 | 12:18 AM
  #45
dodgeramguy85
Thanks, After doing my truck I dont think there is a paint color/scheme that black wheels wont look good on. Im really surprised how sweet mine turned out.
Old Jan 26, 2011 | 12:22 AM
  #46
Blaze10's Avatar
Blaze10
what did you do to do it? i never painted anything before so i am a little scared to do myn lol.
Old Jan 26, 2011 | 12:24 AM
  #47
thunder98110's Avatar
thunder98110
just clean the surface and spray it down. really easy. you cant really mess up. i did mine in a parking lot.
Old Jan 26, 2011 | 12:28 AM
  #48
Blaze10's Avatar
Blaze10
no sanding?
Old Jan 26, 2011 | 12:30 AM
  #49
thunder98110
none at all.
Old Jan 26, 2011 | 12:39 AM
  #50
dodgeramguy85
Its really easy. I just got 4 cans of plasti dip http://www.google.com/imgres?imgurl=...:1&um=1&itbs=1 You can pick it up at lowes,homedepot,ace hardware and so on. Then I took my wheels off and cleaned them REAL good. I spent about 15-20 min on each wheel making sure the rim was as clean as possible then I let them dry cleaned them with a rag to make sure they were good and I taped them off. I did 6 coats for each wheel which is about a can per wheel. Time goes fast they say 30 min for each coat but I did it when it was pretty much dry about 15 min and that was good time because after I got to the last wheel the first one was almost ready to be sprayed again. Then after my last coat was done I let them sit for about 4-5 hrs that was in 75 degrees you will have to adjust time according to what temp you are dealing with.
