Replacing evap/heater cores soon
Old Feb 9, 2011 | 05:41 PM
01BlackDakQC4x4's Avatar
01BlackDakQC4x4
Default Replacing evap/heater cores soon
Hello! In the next few weeks I’m going to have my evaporator and heater cores replaced, which I’m sure you all know is located behind the dash, at the dealership where I work for far cheaper than it would normally cost. I was also told to replace the blower motor and air filter while they are back there. Is there anything else back there that I am not thinking of that I should have checked/replaced? Also I would love to change the dash, radio, AC controls, etc light set up from the stock green to another color... possibly blue or maybe just clear. Does any know if that can be done and if there is a kit or something that I should buy in order to get that done?
Old Feb 10, 2011 | 12:08 AM
jondakotaguy's Avatar
jondakotaguy
Have them check swap the foam gasket to rubber on the intake (above fan) where main door is) that goes up against the frame opening for the outside air..
Make sure they use rubber gaskets there where the tubes go through the firewall and not that foam bs they like to use..
Old Feb 10, 2011 | 09:09 AM
Josh Abels's Avatar
Josh Abels
Yes the lights can be changed just search for threads on here I no myself as well as a few other members have done it and created threads we got our lights from superbrightleds.com good pricing and its real easy to do. U can't get clear as the gauge faces are tinted blue so u can only get combos of something and blue ie red lights would show up purple
