Want to Switch Doors... Compatibility Question.
Old Sep 18, 2011 | 08:53 PM
Y2kkustomes's Avatar
Y2kkustomes
I did this in my ram but i had to run my own power wires and so on it can be done with out the pcm you just have to have a little electrical now how you will need relays one for each window, wire, solder, shrink tube and a wireing diagram for the window switches
its not hard if you know electical
I had a leg up as i used to install many aftermarket systems and alarms and remote starters for a local dealer ship
Stick to it and you will win just get the doors or guts from a nother truck look in your local classifieds for people parting out their trucks.
Old Sep 19, 2011 | 09:19 PM
chris1996's Avatar
chris1996
why dou you want so much power windows...?
Old Dec 12, 2011 | 12:34 AM
5hundo's Avatar
5hundo
I was thinking about this exact idea the other day: I could just by-pass the PCM and hard-wire the electroncs for the doors. I might have to look into doing that...
Well, when I get pulled over, the cop walks around to the passenger side and I have to reach over to roll down the passenger window manually. Its inconvenient...
Old Jan 6, 2012 | 11:37 AM
mgaither0's Avatar
mgaither0
how this coming along? I had this idea the other day. i was sitting in my truck and saw how the cover pops off to put the switches in for power windows and locks. I just recently went from a 01 1500 dodge ram sport 4x4 loaded to the 99 dakota manual windows locks, 2wd, 3.9v6 so its a big step down. I like the dakota but miss the ram. Any how I was curious how hard it would be to do this swap. Any progress since?
Old Jan 23, 2012 | 07:35 PM
5hundo's Avatar
5hundo
Having trouble finding parts, honestly. I'm going to have to open myself up to other color options besides Atlantic Blue. I need a fender too and I can't seem to find one anywhere in my truck's color. It's going to need some touch-up anyway, so I might do just that.
I will also have to find a place willing to deal because I'm not paying a fixed price for all of the components inside the door. If it's cost prohibitive, I won't do it...
It's already going to be complicated enough to wire up the relays and what-not...
Old Apr 21, 2017 | 09:55 PM
nholt's Avatar
nholt
I had this exact same question! Glad somebody else had the same idea. I have a 2000 Dakota with manual crank windows. My AC is not working right so I'm driving with the windows down (It's already in the upper 80's down here) but it's a pain in the *** to reach all the way over to lower and raise the passenger side window! And when I leave a parking lot I like to lower the windows a bit to let the hot air out. Power windows would be soooo much more convenient.
I think I'm just going to get my AC fixed lol
Old Apr 22, 2017 | 09:53 PM
bradz's Avatar
bradz
Originally Posted by 5hundo
Hey guys...
I have a 2003 Dakota 4x4 extended cab that I bought new in 2003. When I bought it, I wanted one with a V8 and a stick shift but all the ones I was looking at only came with manual windows and locks.
I was thinking that if I could find the doors with the power windows and locks already installed that I could swap them out with minimal issues. So, I had a couple questions:
1) Are all Dakotas pre-wired for power window and locks, or will I need to wire it?
2) Where would be a good place to look for a complete door? Any good online sources?
I did this to my 97 from a 99 and i had to have all the wiring from inside the cab (yes even the harness connected to the back of the dash) and all the wires under the hood. I even swapped the harness that runs to the back of the truck just to be safe. I started with just the doors but then noticed there wasn't a plug for the power option going from ctm to doors so i had to change the whole dash, then my headlights wouldn't work so i had to swap the under hood harnesses so i figured i might as well swap yhe back too. I might have had so many problems because they were different years but just a heads up of what you might be getting into.
