Parts List for R/T
Old Feb 16, 2011 | 05:15 PM
bigreed91's Avatar
bigreed91
Default Parts List for R/T
So after doin some reading this is what ive come up with that id like to work on getting this summer.
Comp cams roller rockers with 1.6 ratio
Edelbrock Performer RPM Aluminum Cylinder Head 176cc Intake Ports 58cc Combustion Chambers 2.020'' Int/1.600'' Exh Valves 1.460'' Valve Springs, .580'' Max Lift
Lunatti Voodoo Mechanical Roller Camshaft
Lift: .555''/.566''
Adv. Duration: 261°/267°
Duration @ .050'': 231°/237°
RPM Range: 2500-6400
Mopar 2 bbl mpi,aluminum,single plane, magnum direct replacement, with out EGR 1997-02 5.2/5.9 same height as stock manifold.
It all comes to a total of about $2500 without shipping. Ill be out to sea about half of the summer so i should be able to save some money.Also this doesnt include the smaller things id likely replace while its apart like push rods, timing chain, etc. But hot rod magazine did this setup and it brought their 5.9L magnum up to 448hp and 434lb-ft and they started at 300hp. Also im about to get a 52mm tb and injectors from 1999blkdakrt. So how does this sound for starters?
Old Sep 11, 2011 | 11:14 AM
vimnjicki's Avatar
vimnjicki
hey! sounds great to me. I have a 5.9 block in the machine shop right now prepping it for what sounds like a very similar build except mine is on a '97 Dak Sport 4x4. Just wondering if your plans ever came to fruition or if life "got in the way"? What did you do about the increased power and the transmission?
Old Sep 11, 2011 | 11:29 AM
thunder98110's Avatar
thunder98110
he totaled his truck like 3months back.
Old Sep 11, 2011 | 09:40 PM
vimnjicki's Avatar
vimnjicki
wow. that really sucks. sorry for him. really.
