Can you swap out the 9" back brakes to the 10" brakes?
Old Sep 9, 2011 | 10:28 PM
98DAKAZ's Avatar
98DAKAZ
Lightbulb Can you swap out the 9" back brakes to the 10" brakes?
I have the 9" back drum brakes and don’t like them I think they are a bad design and have never worked very well can you swap them out for the 10" drum brakes is it just a bolt on change?
Or better still disk brakes for the back
My truck is a 1998 base Dakota 2.5L stick
Old Sep 10, 2011 | 09:16 AM
98DAKAZ's Avatar
98DAKAZ
Default maybe what I should be looking for is
Maybe what I should be looking for is
A used rear end with the 10” brakes and 3.90 gearing does anyone have one?
Old Sep 10, 2011 | 10:24 AM
moparman_2004's Avatar
moparman_2004
Well I would find a wrecked one from a 04 or something so you have disc breaks mine has a 9.25 rear with a lsd 3.92 gears and has disc breaks
Old Sep 10, 2011 | 12:11 PM
98DAKAZ's Avatar
98DAKAZ
Smile so a 2004 is the one Im looking for?
Thanks moparman_2004
So a 2004 rear-end is the year Im looking for with disk brakes?
I was wondering what year I needed to look for.
Do you lose the parking brake with the swap?
The ABS system works with the swap or other mods will be needed?
Old Sep 10, 2011 | 11:23 PM
cowboy63645's Avatar
cowboy63645
Mine is an 03' and I have rear disk brakes as well, and you will have to change the rear most cables for your e-brake to hook up and work properly, also you will need the portioning valve for the disk brakes instead of the drum.
Old Sep 11, 2011 | 05:35 PM
98DAKAZ's Avatar
98DAKAZ
Smile Thanks for the suggestion people
Thanks for the suggestions people I appreciate the help
Old Sep 11, 2011 | 08:02 PM
dodgeramguy85's Avatar
dodgeramguy85
I've just heard that the rear discs dont stop as effectly as drum brakes. Not saying it's true but just what I heard.
Old Sep 11, 2011 | 08:25 PM
98DAKAZ's Avatar
98DAKAZ
Cool anything is better than the 9'' brakes
Anything is better than the 9'' brakes I have they suck.
Besides Disk are so much easier to work on like night and day I’ll take Disk any day over Drum.
I hate all those springs and gismos in Drum brakes
Look at this junk
Old Sep 11, 2011 | 09:42 PM
dodgeramguy85
Once you do it enough it seems just as easy as calipers. I've done like 10 in the past year I can do a side in 15min disassemble and reassemble
Old Sep 11, 2011 | 09:50 PM
98DAKAZ's Avatar
98DAKAZ
Default How the hell
How the Hell do you keep the shoes from popping out as you try to snap in a spring just infuriates me do you use special tools that make it easier?
Those 9" brakes are crap at best I think the 10" are a better design.
