turn signal wiring
Old Feb 17, 2011 | 03:25 PM
jimmielewis's Avatar
jimmielewis
Default turn signal wiring
Does anyone have the wiring diagram for the trun signals?I am installing new side mirrors with led signal arrows and I need to run the turn signal wiring to them. I have a 2001 Dakota.
Old Feb 17, 2011 | 04:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site.
Check here in the 2nd Gen Dak section
https://dodgeforum.com/forum/2nd-gen-dakota-67/
Old Feb 17, 2011 | 07:46 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the second generation Dakota section,
FF
Old Feb 17, 2011 | 10:02 PM
01SilverCC's Avatar
01SilverCC
From reading the service manual, it looks like the easiest way is to remove each parking light assembly and splice into the positive turn signal wire there. It's at the Power Distribution Center too but it looks like a lot of trouble to get to the right wires. Look for light green on the left side and tan on the right. Be sure to check each one with a volt meter to be sure you have the right wires.
Jimmy
