Door Panel
Old Feb 22, 2011 | 10:24 AM
jondakotaguy's Avatar
jondakotaguy
Junkyard
Old Feb 22, 2011 | 12:27 PM
Lebbie54's Avatar
Lebbie54
Alright I called around the local junkyards no one had it local. So I might have to order it the LKQ corp (national chain of salvage yards). But then again I might not have to. I went to the hardware store to try to figure out something that might work until I get the panel. Well I came up with cutting a strip of mending bracket which is about 1/4 thick and has holes in it, and getting some JB weld epoxy. I glued a piece of the bracket down that I cut to fit. The epoxy says it has it will hold up to 3600 psi so I think this should work long term, as long as I let the epoxy set up fully.
