screaching noise
Old Feb 21, 2011 | 02:07 PM
Blaze10's Avatar
Blaze10
Default screaching noise
so with all this bad weather pa has and the road salt and crap my truck is screeching when i turn the steering wheel left and right but only when its stopped. also when i hit bumps or push up and down on the front end i can hear it really badly it sounds so so so bad, i checked ball joints, wheel bearings, nothing it broken i filled the ball joints with grease the only thing i think it could be is the tie rod ends maybe dry or something any help would be appreciated.
Old Feb 21, 2011 | 02:14 PM
DakMan6704's Avatar
DakMan6704
video?
If it was a ford, Id think steering pump...still could be, but would do it all the time. Might be ends, or sway bushings. I replaced mine and it quieted down a lot! not a bad say, hour job....
Old Feb 21, 2011 | 02:19 PM
Blaze10's Avatar
Blaze10
well they look fine i checked them as well. its really annoying and loud, makes my truck seem and look like poop
Old Feb 21, 2011 | 02:37 PM
McNasy's Avatar
McNasy
more than likely it is your front swaybar bushings. mine are really aweful this time of year, they do everything you decribed above. this topic has been dicussed on here before. our bushings just suck.
Old Feb 21, 2011 | 02:58 PM
Blaze10's Avatar
Blaze10
sorry for not searching that is my bad, i just wasn't sure, my friend said his sway bar end links or w.e were snapped off when his did this and i checked and they looked fine. the bushing looks fine?? i know i need rear ones. maybe ill just take it to a garage have them replace them all cause i am taking it to get the crank seal fixed anyway
Old Feb 21, 2011 | 03:12 PM
DakMan6704's Avatar
DakMan6704
Well, you dont have endlinks, up front...but I would see if they will do it for a few bucks. Its literally a hour and a half going slow...maybe $75 in parts(Moog). I can get you some part numbers cause, I just did this a month or so ago...or, user RockAuto...you need to get the diameter of your Sway bars...front and rear tho...cause dodge was smart and made like 3 of each.
Old Feb 21, 2011 | 03:20 PM
Blaze10's Avatar
Blaze10
two for the back for myn is 16 for the rear and idk the front
Old Feb 21, 2011 | 03:38 PM
McNasy's Avatar
McNasy
if your gunna go with new bushings up front, i do believe poly is the way to go. it will get rid of the squeekin we get this time of year. btw, it took me only an hour to change the front bushings and the rear links. super easy to do urself.
Old Feb 21, 2011 | 11:49 PM
Blaze10's Avatar
Blaze10
sounds good and yeah i read the post about the rear linkage and bushings and saw how easy they were. i am gonna jack it up wed, check it out and go from there.
Old Feb 22, 2011 | 01:08 PM
Blaze10's Avatar
Blaze10
this is what i meant by end links i ment sway bar links my bad. i will have to check into this
http://cgi.ebay.com/ebaymotors/2-Fro...Q5fAccessories
