Dakota missing on #3 cylinder
Old Feb 22, 2011 | 07:08 PM
Mark Sholar's Avatar
Mark Sholar
Default Dakota missing on #3 cylinder
2000 Dodge dakota 4.7 engine.Throwing P0303 code, engine running rough. Checked spark plug connections and connector to injector.Any suggestion?
Old Feb 22, 2011 | 07:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
Pull the plug, see what it looks like.
You could always swap a coil and see if the problem follows.
Old Feb 22, 2011 | 07:56 PM
bpark8824's Avatar
bpark8824
Yeah, usually on engines with individual coils, the coil is the root of any mis fire problems. But plugs are a lot cheaper so I would start by checking the plug and then like DakDan said, swap the coil with a working cylinder and see if the problem moves to that cylinder. Plugs and coils are really easy to do on a 4.7 so it shouldn't take long to figure it out unless its more of an electrical issue.
Old Feb 23, 2011 | 08:36 PM
Mark Sholar
Thumbs up
Switched coil from #3 cylinder to #1 problem followed giving a code of P0301. Installed a new coil, truck runs like new again.Thanks guys for the much needed help.
Old Feb 24, 2011 | 05:57 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it fixed. Thanks for letting us know.
Old Feb 24, 2011 | 09:10 PM
bpark8824's Avatar
bpark8824
Good deal. At least it was a pretty easy fix and not a more complicated electrical issue. Those are my worst nightmare as they can be a pain to trace. Glad everything worked out.
