1999 dakota 4x4
Old Feb 26, 2011 | 09:28 PM
99-318's Avatar
99-318
Default 1999 dakota 4x4
So a while ago I replaced upper driver side ball joint, Passenger hub unit, Passenger cv shaft, passenger side inner and outter tie rod ends, just yesterday I jacked the truck up, upper passenger ball joint shot, and inner and outter tie rod ends on the driver side. So I get them, Put them in, Go test drive it, Steering is solid but wheel is at 10 o'clock goin straight. When I turn sharply to the right something is binding, Got an alignment thinking that was my problem, Turns out it was'nt im at home in langley now and cranked er right to come into the driveway and it binds the same way, Get my brother to drive back and forth while I look and something is defentely rubbing or binding but I cant see what, You guys think my cv shaft on the driver side is gone now?
Old Jun 27, 2012 | 05:08 PM
bbeebee's Avatar
bbeebee
no idea
