44re Transfer Case Fluid?
Old Mar 3, 2011 | 02:42 PM
jondakotaguy's Avatar
jondakotaguy
Default 44re Transfer Case Fluid?
Question. I was reading my manual and it shows for the Transfer Case it shows an ATF Special?
This is a 44re Transmission
Should I use ATF-4 for the transfer case?
What is the correct fluid for the Transfer Case?
How much does it typically take?
Old Mar 3, 2011 | 02:49 PM
thunder98110's Avatar
thunder98110
use the atf+4 fluid. i think its like 2qts. but buy 3qts.
Old Mar 3, 2011 | 02:51 PM
jondakotaguy
K thanks.. manual called for ATF Special or something like that.. I forge with out re-reading it.. I asked parts store and they are like I have no clue what that is.. and never heard of it.. Think it might of been a mopar only fluid..
Old Mar 3, 2011 | 02:52 PM
thunder98110
yeah mopar atf+4
Old Mar 3, 2011 | 08:48 PM
UWAdventurer's Avatar
UWAdventurer
I used ATF+4 with no probs in my '97.
Old Mar 3, 2011 | 10:32 PM
jondakotaguy
Yeah.. did this today.. and did not help my shutter/loping problem when creeping.. or stopping or foot off the break without pressing the gas problem..
All well.. at least the trans is fully serviced now.. did notice a small leak on the main seal.. but had plenty of fluid in it.. almost full... and the leak is only a drop.. sitting there.. not really falling to the ground.. truck sits alot and I never see trans fluid on the garage floor.. so.. I'm not gonna mess with it..
One thing though.. put it in 4x4 to make sure its nice and loobed or w/e..
These things have week 4x4's.. or it just feels so much different from my old Jeep Wrangler..
4-Wheel HIgh.. seems like 2-Wheel high.. and 4-wheel low.. feels like 4-wheel high in my old wrangler.. ROFL..
Weird..
Old Mar 3, 2011 | 10:33 PM
jondakotaguy
OH.. did notice.. WOT.. the truck for some reason since I cleaned the TB out really good.. shifts from 2nd to 3rd about 4,000k or so..
Manually shifted 1, to 2... then to drive.. WOT.. SO MUCH BETTER...
Old Mar 4, 2011 | 09:33 AM
moparman_2004's Avatar
moparman_2004
i used schaffers atf with no issues in the tranny and transfer case
