Steering Shaft U-Joint
Old Mar 4, 2011 | 09:28 PM
stampede 04's Avatar
stampede 04
Default Steering Shaft U-Joint
Today I think I figured out what has been causing hard steering on my 04 3.7 2wd reg cab dak. I sprayed the steering shaft U-joint and it steered fine after that. My question is....does this have to be replaced? Does it mean it's worn out or is it just a matter of lubrication? If so, how difficult is it to do?
Old Mar 5, 2011 | 11:40 AM
dodgeramguy85's Avatar
dodgeramguy85
I think there was a recall on them for one of the years not sure which. I think most of the guys that have this problem just spray theirs every couple months to keep it from getting tight.
Old Mar 5, 2011 | 12:30 PM
stampede 04
thanks for the info dude. I used wd-40, but is there a better lubricant to use on it that you know of? Would a thicker oil or grease be best?
Old Mar 5, 2011 | 05:11 PM
dodgeramguy85
White lithium grease made by crc. We used to use it on our tree spade at work and it was some good stuff lasted awhile too
