P code problem
Old Mar 5, 2011 | 04:36 PM
mazz3242's Avatar
mazz3242
Default P code problem
I plugged my truck into a computer thing at the dealership i work at. the code it gave me was P0551 for the... Power Steering Pressure Sensor Circuit Range/Performance...should i replace the sensor or just replace the whole power steering pump..witch one is cheaper
Old Mar 5, 2011 | 05:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
Try the pressure switch (sensor). It only takes a few minutes and they have a habit of leaking on the Dakota sending PS fluid into the PCM.
It's a lot cheaper too!
Old Mar 6, 2011 | 04:44 PM
mazz3242's Avatar
mazz3242
yea ill try...but how do u do it
Old Mar 7, 2011 | 03:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
How do you change it? Pick up a new sensor. You should see it in the high pressure line near the pump.
Remove the connector. Clean the area first then unscrew the old one and screw in the new one. Tighten it to about 10 - 15 foot pounds, fairly snug. You'll lose a little fluid so have a rag and be ready.
Old Mar 9, 2011 | 02:04 PM
mazz3242's Avatar
mazz3242
ok how much does a new sensor cost, and should i go in from the top or bottom of the truck
Old Mar 9, 2011 | 02:42 PM
00DakDan's Avatar
00DakDan
Section Moderator
What year and engine is your truck?
About $15 for mine.
Old Mar 11, 2011 | 09:53 AM
mazz3242's Avatar
mazz3242
i have and 01 with a 4.7
Old Mar 11, 2011 | 05:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
You can do it from above, its right off the pump, on the high pressure line.
