Injector problems
Old Mar 7, 2011 | 06:25 PM
JbDodge2000's Avatar
JbDodge2000
Default Injector problems
I have a 2000 dodge dakota with a 4.7..bout 85,500 miles on it..in the last week, the computer read the i lost 4 injectors, p codes 0201,0202,0207,0208 also with a p0171 code. I replaced injectors on 2 and 1, and switched the injectors from 7 and 8 to 2 and 3 the other day. Today it read i check engine code 0206 but the other 2 codes didnt come back. I check the fuel rail and it was clean as a whitsle. I have no idea whats going on, anybody have any ideas on whats going on?
Old Mar 7, 2011 | 08:18 PM
Senate427's Avatar
Senate427
Check the fuel injector wiring to see if it isn't faulty and that each wire has power. I had the same problem with my 93 and I cleaned every injector and still my engine wouldn't fire right. So as I looked closer I noticed the contacts on two fuel injector wires were burnt and I had to get new connectors. Also it's possible one of your injectors maybe clogged even though you clean them. Try resetting the PCM and see what happens.
