problems with stalling
Old Mar 17, 2011 | 07:34 AM
tabadboy's Avatar
tabadboy
Originally Posted by olsarge
Another cause is low tranny fluid. Makes the tq stay in lockup mode and not enuff rpms at stop to keep it going.
Well tried the cleaning the iac and it ran great that night but went back to dying out.It now starts up and idles rough.I will check the tranny fluid today.Sunday I will replace the IAC and ABS sensor.Hopefully that will take care of the problems.If not i wil be back on here lol.
Old Mar 17, 2011 | 01:36 PM
TheePlaymaker's Avatar
TheePlaymaker
Mine did that when I got it and they replaced the IAC and the PCM...they steam cleaned it or something and it burnt up the PCM I guess. It would randomly buck/die and wouldn't idle for crap. Id try the cheaper things like you said but that could also be a culprit.
Old Mar 17, 2011 | 08:42 PM
bigreed91's Avatar
bigreed91
If cleanin it made it run good for that night id assume a new one would fix your problem. Mine just randomly went out, the truck wouldnt even start unless i gave it gas and as soon as i let off it would die.
As you can see it was completely black.
Old Mar 22, 2011 | 07:50 AM
tabadboy's Avatar
tabadboy
Well I put a new IAC on my 98 and it ran great for 2 days.This morning when i got ready to leave work it died again.It took about 4 minutes of trying to start it and it started up.It ran great all the way home and did not die out anymore.Guess I'll have to try something else.
Old Mar 22, 2011 | 10:58 AM
bigreed91's Avatar
bigreed91
Hmmm thats weird
Old Mar 22, 2011 | 12:53 PM
alleymad99SLT's Avatar
alleymad99SLT
Actually my brake light and abs light then come on a couple times.One time they stayed on till i turned the key off.What is the iac and where is located? Thanks
Originally Posted by alleymad99SLT
You need to replace the ABS / Speed Sensor thing in the top of the rear differential as well...that is why the ABS light is coming on...
The computer uses that sensor to work the IAC and if it is not working properly, the IAC will not work properly...eventually, if it gets bad enough, it will stall every time you come to a stop...
Where do you stand regarding this exchange??
Old Mar 22, 2011 | 01:29 PM
tabadboy's Avatar
tabadboy
I just drove it to go pay a bill.No problems.When i got home this morning I disconnected the battery.i figured i would let the computer reset itself.I need to use it to go to work the rest of this week.I will try a new ABS sensor this weekend and let y'all know how it goes. Thanks
Old Mar 24, 2011 | 07:22 AM
tabadboy's Avatar
tabadboy
Well I could not wait till the weekend.I went ahead and replaced the ABS sensor it made no difference still stalled on me.I guess its time to spend the big bucks and buy the fuel pump next.When it died on me last night i was able to pump the gas and keep it from dying out completely.I will have to wait till next week cause i don't the $254 for the pump this week.Will let yall know what happens.Thanks
Old Mar 24, 2011 | 12:10 PM
alleymad99SLT
Did you reset the computer after installing the new sensor?
Also need to make sure that the wiring harness for the sensor is not the issue as well...
Old Mar 24, 2011 | 08:26 PM
dakoman859's Avatar
dakoman859
my dakota does the same thing but its like when there is lots of gas in it it works perfect
