What is the Smell?
Old Mar 12, 2011 | 07:41 PM
Senate427's Avatar
Senate427
Default What is the Smell?
97 Dakota 5.2 ext
I've owned my 97 Dakota for less than a year now and ever since I bought it has had a odd smell to it. It smells like dampness in an old basement or wet dog kind of smell. My first thought was water is leaking into the truck when it rains, but I haven't found any signs of water being on the interior. Even 7 days of dry weather the truck will smell. Only in the cold winter will the truck not smell. Basically if I put the windows down the smell will go away until I leave the truck to sit over night.
Anybody have an idea? I've tried using fabric/rug cleaners to get rid of the smell, but no luck.
Thanks
Old Mar 12, 2011 | 08:51 PM
britgeezer's Avatar
britgeezer
Have you checked the heater core, strange smells are often coolent leaks, ....hard to find or reach.
Try some "bars leaks" or similar to fix small weeps, cheap and effective.
Old Mar 12, 2011 | 08:58 PM
Senate427's Avatar
Senate427
hmm.. I replaced my radiator, water pump, and hoses back in the fall, so I know that's not leaking. I would think the heater core would smell like syrup if it were leaking.
Old Mar 12, 2011 | 09:30 PM
britgeezer's Avatar
britgeezer
Depends on the coolant and additives you use. Its a less than $5.00 test.
Old Mar 12, 2011 | 11:58 PM
Senate427's Avatar
Senate427
I found something that might have told me the answer. And I quote from another website
(2) SMELLS LIKE: GYM SOCKS
Originally Posted by http://www.popularmechanics.com/cars/how-to/repair/2423551
WHEN: You turn on the heater/air-conditioner fan and you get a whiff of that high-school gym locker.
THE CULPRIT: It's good, old-fashioned mildew growing in the moisture condensing inside your a/c evaporator. And no, drizzling Listerine down the vents won't fix it, in spite of what your brother-in-law read on the Internet. Check popularmechanics.com/musty for advice on curing this. Cheap solution: Turn off the a/c a mile from home and run the fan on high to dry the system out.
Guess what my A/C condenser does have a hole and always has since I bought the truck.
Old Mar 14, 2011 | 11:24 AM
jondakotaguy's Avatar
jondakotaguy
That sucks.
Old Mar 14, 2011 | 01:57 PM
Blaze10's Avatar
Blaze10
oh boy
Old Jun 5, 2011 | 05:40 PM
xX_Devious_Xx's Avatar
xX_Devious_Xx
That sounds like mine, I have that musty smell in mine and I have tried looking into it but it seems I have to take everything out of the cab to get to it. I have looked all over and don't see an easier way of doing it unless someone else does. Good Luck
Edit: Also I think mine has a leak as well because my a/c works when it wants too. I run a vacuum on it fill it and it stays cold for a few days then just doesn't get cold cold like it should.
