3.9L auto 2nd to 3rd shift problem
Old Mar 20, 2011 | 02:22 PM
g0ttadrift's Avatar
g0ttadrift
Default 3.9L auto 2nd to 3rd shift problem
Alright so I bought the truck 2 years ago knowing this problem exists. It's an automatic transmission and when shifting between 2nd and 3rd, it feels like the bands are slipping. Around 35-40mph and about 3500rpm, the engine will rev high and I have to let off the accelerator in order for it to shift. It's right at that shift point and I checked the bands by performing a stall speed test in D, R, and 1. I'm almost conifdent it is a hydraulic problem because the transmission idles good, shifts smooth in every other gear, and does not make any noise. Fluid is nice and red. I'm ready to fix the problem now, but for 2 years, it has driven this way; another reason I dont feel it is mechanical becasue something would have given by now. I'm leaning towards a check ball getting stuck and rebuilding the valve body. Anyone else know of this problem?
Old Mar 20, 2011 | 05:30 PM
frydaddy82's Avatar
frydaddy82
mine done the same thing when i bought it and i surfed this forum and found out that the t.v cables or better known as kick down cables become woren and need to be adjusted from time to time. i adjusted mine and it shifts perfect now. might wanna do filter change and ad some lucus no slip with your new tranny fluid.
Old Mar 21, 2011 | 02:24 AM
wewanaplay's Avatar
wewanaplay
Are you serious? You've actually been driving this truck for 2 yrs this way???
Old Mar 21, 2011 | 10:26 PM
frydaddy82's Avatar
frydaddy82
yea man the guy i bought mine from drove it for 3 years shiftn like that lol i adjusted it and shifts like a champ now
Old Mar 21, 2011 | 10:37 PM
g0ttadrift's Avatar
g0ttadrift
lol yea thats why i was thinking it had to be something other than whats inside the transmission. thanks man. I will let you know if this works. I hope to get to it this weekend.
Old Mar 21, 2011 | 10:46 PM
yenner's Avatar
yenner
Does anyone have a DIY for the adjustment?
Old Mar 22, 2011 | 06:10 AM
2001DodgeMan's Avatar
2001DodgeMan
I would like to know this as well,would add to the excellent stuff I've found here,knowledge is great
Old Mar 22, 2011 | 10:50 PM
g0ttadrift's Avatar
g0ttadrift
I do in the Haynes manual I have. I will post it here when I get some time. Definately by the weekend.
Old Mar 23, 2011 | 05:07 PM
yenner's Avatar
yenner
Thanks. I'd appreciate it.
Old Mar 27, 2011 | 08:16 PM
g0ttadrift's Avatar
g0ttadrift
Ok I adjusted my TV cable yesterday but it didnt seem to help. I didnt look at the resting position on the trans becasue it was too cold to get on the ground so I'll prob have to re-do this adjustement. Anyways, yenner... here's the adjustment:
***Adjusting your TV cable***
-Start by removing the airbox going to the throttle body and elbow. On the right side of the engine, you will see your throttle cable, cruise control cable, if you have one, and your TV cable. The TV cable is the one that is farthest right and closer to the firewall. The cable is moved opposite the other cables. Start by removing the connection to the throttle body. It's a ball and sleeve type so it should just slide off, with force! lol. But dont break it! Then remove the retaining clip (it's whiteish in color and is close to right where the TV cable housing mounts to the bracket right by the throttle body. Move the cable in and out to take up the slack and re-mount the cable back on it's ball. Let the cable go to the fully closed position and re-install the retaining clip. The TV cable should now be correctly adjusted. Put everything back together.
