Help! P0751
Hi! I'm looking for some help. I got a friend that owns a 1998 Dak 5.2 l auto. He went to autozone to read a code and this is what the scanner said:
P0751 O/D Switch Pressed (Low) More Than 5 Minutes
Anyone have this problem before and knows how to fix it?
Any help will be appreciated!!!
Thanks
Thanks
This is from the Chilton Library, 1998 Dak 5.2 Auto.
Trouble Code: P0751 (5.2L V8 VIN Y Auto)
A/T Overdrive Switch Pressed Low For Over 5 Minutes
Print this code data
Number of Trips to Set Code: 1
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Engine started; engine runtime over 10 seconds and the PCM detected the Overdrive Off Switch indicated "low" for over 5 minutes.
Possible Causes:
- CCM Details
Possible Causes:
- Overdrive Switch Off" circuit is shorted to ground
- Overdrive Switch is damaged or has failed
- PCM has failed
Thanks for the info guys! I told my friend that imo the easiest and cheapest way was to find a overdrive button and swap his out. I told him to go to a junk yard and find one or i told him where to get it online for $13.00 shipped to his home.
We'll see.
Any other suggestions, tips etc. feel free to post them!
Thanks....
Hector......
We'll see.
Thanks....
Hector......
I have the same code for my truck. 1998 Dodge Dakota 5.2 l auto. 4x4.
But my reader states Shift solenoid A performance or stuck off.
I do have a slip from 2nd to 3rd. But there is no slip whatsoever when I
do have the O/D off. My O/D switch is damaged, but I am able to turn
it on and off. Just wondering if I still need an A/Trans solenoid.
