Front end noise when in 4wd
My 2001 Dakota V6 makes a growling noise when in 4wd. The noise starts at about 25-30 mph and gets louder the faster I go. The noise is the same when I'm driving straight or turning the wheel, and the noise only happens when in 4wd. I have changed the fluid in the front transfer case, but that didn't help. Are my gears going bad or can it be something else?
It could be the front driveshaft bearing. Yes it is always in motion when the truck is moving, but there is a difference when it is turning and when it is turning with a load applied to it. Thunder had his crap out on him not too long ago maybe check out his posts and see if the symptoms are similar. If not I would agree that it's something in the transfer case. If you have moderate mechanical skills I would think you could takle repairing/replacing a transfercase there isn't too much to them.
