Anybody ever replace their steering shaft?
Here's the link to the place I got the part.
http://www.apdty.com/searchitem.epc?...6AA,55351247AA
It is Auto Parts Direct To You and they're located in Florida. Great price and fast shipping.
I was having a constant squeaking when going over bumps, finally fixed after replacing steering intermediate. Be careful with o2 sensor right next to it, i busted it and had to replace it. No more front end squeaking though. Found mind on eBay motors for about 50.
That is an interesting video. Fortunately, on my 2003 Dakota I only had to replace the lower intermediate shaft (it is a two part shaft on mine) and I didn't have to do anything inside the cab on the steering column.
also when replacing the intermediate make sure that the threaded side of the intermediate is on the back side so the bolt can bite there and pull it together. it sounds like common sense but when at that ridiculous position trying to bolt it on i forgot about it and i bolted the threaded part first, which of course left me having to redo it.also if you have a long (2 ft) extension for your ratchet you'll have an easier time with it as long as you have the front end on jack stands and youre able to turn the steering wheel to get the best access to the bolt from the top side.
What are the Part #(s) for the Upper/Lower intermediate steering shafts for a 2WD (TWO-wheel drive) 1998 Dakota.
I'm ONLY finding ones for 4WD (FOUR wheel drive) ONLY.
Totally different parts.
TIA.
TIA.
I found this shaft, BUT it shows for 2001-2004.
http://clutch-release-bearing.dvauto...w-kkjomrqnrqkk
What year did this part change from 1998 ?????
Apparently, this is the one.
Amazon.com: APDTY 52078808AD Intermediate Steering Shaft Upper & Lower Assembly With Universal Rag U-Joint Coupler(s) For 1997-2000 Dodge Dakota 4x2 2WD / 1998-2000 Dodge Durango 4x2 2WD (Replaces Mopar 5535121AB, 55351209AB, 52078808AC, 52078808AD): Automotive
So what's the difference(s) after year 2000 ? The other listings show 2001-2004.
Brand New Intermediate Steering Shaft Upper & Lower Complete Assembly
Fits 1997-2000 Dodge Dakota 2-Wheel Drive
Fits 1998-2000 Dodge Durango 2-Wheel Drive
Fits RWD/2WD (Rear Wheel Drive, 2-Wheel Drive) Models Only
Redesigned to prevent future failure & eliminates clunking noises in steering column
Both upper and lower intermediate shafts included & come pre-assembled for easy installation
Replaces Factory Part #'s 5535121AB, 55351209AB, 52078808AC, 52078808AD
Auto parts warehouse
Steering Shaft 1999 Dodge Dakota Sport 8 Cyl 5.2L Replacement Steering Shaft Dakota Replacement
Price: $ 99.52
Qty: 1.00
Part #: REPD281701
for my wifes 2wd 99 dakota
that was like over a yr ago, i found it thru amazon
Price: $ 99.52
Qty: 1.00
Part #: REPD281701
