New to forum
Old Mar 31, 2011 | 07:44 PM
mcusey's Avatar
mcusey
Default New to forum
Hello, I had a question about doing a custom exhaust. I really want to do a true dual exhaust but the factory setup goes into a single pipe and another cat with an o2 sensor after it. My question is do i need to have that cat there or will it trigger a check engine light? Also what would I do with the o2 sensor for the other pipe? Any advice would be greatly appreciated.
Old Mar 31, 2011 | 08:01 PM
bigreed91's Avatar
bigreed91
Taking the cat off wont throw a code but if you have to have emissions or an inspection for your truck it wont pass. As for the sensor after the cat ive aleays heard to just zip tie it to the frame leaving it connected, or you can spend the money to get somethin to plug in its place but i aint sure what its called. Also welcome to the forum, you'll find lots of good advice here.
Old Mar 31, 2011 | 08:20 PM
thunder98110's Avatar
thunder98110
an 02 simulator i think^
Old Apr 1, 2011 | 03:56 PM
mcusey's Avatar
mcusey
thanks. ill look into the simulator and I dont have to do those stupid emissions tests so i should be good there. Thanks for the help
